This Bronco was sold in Colorado and used at 5000 feet elevation. I'm not all that familiar with the terminology, but I'll try to describe the system. The hose connections described here may be incorrect.
There's an EGR valve on the back of the carb. plate, a 3-port PVS valve on the coolant outlet, a similar 2-port valve on the heater supply line, a valve (I presume) on the transmission, a 2-port manifold vacuum source, and 2 vacuum ports on the 2 barrel Mortorcraft carburetor, one on front and one on the right side.
The current connections are as follows: line from manifold vacuum to the air cleaner valve; and a line from the manifold vacuum, thru the transmission valve, to the EGR valve. A T from this EGR line goes to the heater hose valve. The 2nd port of the heater hose valve goes to a four-way splitter connecting both carburetor vacuum sources with the top of the PVS valve. The bottom of the PVS valve connects to manifold vacuum and T's to the retard side of the distributor. The center port of the PVS goes to the distributor vacuum advance.
Most seems ok, except the two vacuum ports of the carb being connected together, and the manifold vacuum being T'ed to the carb vacuums. If you can comment on these connections, it would be appreciated. I could email a diagram if there's a way to email directly to you. My email is
grrubin@earthlink.net
