You can fix it without taking the box out. There are actually 2 seals there, one on top the other. Pull the pitman arm off and remove the snap ring. Then start the engine and turn the wheel until the pressure pushes the seals and washers out. Then put the new ones in. The two seals are different so pay attention to which one goes in first.
I know this is a bit old, but I did this about a month ago using this tip and it was amazingly easy!! I'll add something to it though, which I think makes it even easier.
1) drop pitman arm
2) remove snap ring
3) put pan under box (it's gonna get messy!) turn sterring a little bit till everything pops out
4) set the new seals in the correct order (yes they are different), tap in the first seal, then set a metal ring on the second seal and start it in (I used my 34mm spindle nut socket to hammer them in). For the end part, I used the two metal rings that came out of my box on top of the new seal and new metal ring. The two old metal spacers pushed the new stuff in far enough that I could get the new snap ring in behind them. It was so quick and easy, I don't know why anyone wouldn't just do it than buying stop leak stuff. ;D
Hope it helps someone take the plunge!!
Andrew
