    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
CA Smooth Shift Collar For Floor Shift Conversions
Status
Not open for further replies.
72Sport
THE AD IS OLD BUT INVENTORY IS GOOD AS OF 8/7/12.
The collar and turn signal switch mount replaces your stock gearshift collar and turn signal switch mount when you go to a floor shift. If your column is an automatic you need both the turn signal switch mount and the smooth shift collar (2 or 3) $30. Your automatic turn signal switch mount does not have the mounting holes for the collar nor any room to drill them. I have turn signal switch mounts for both emergency flasher switch on the column (3) $30 and for the early ones that either don't have an emergency flasher switch or the switch is on the dash (2) $30. If you have a manual shift column now you can reuse your switch mount and save on shipping and the cost of the switch mount. The collar only is(1) $20. All collars and switch mounts need to be painted. The factory paint has a lot of defects either from wear or quality of the original paint. Pictures are sample only. You probably receive a color other than black. Shipping for all 50 states is $10.40 or less depending on zip code for both the collar and the switch mount. If you need only the smooth collar and mounting screws shipping is $6.30 or less.
I HAVE MORE THAN ONE OF EACH.
JeepGuy
Might need one of these when i pick up the bezel set.
rcmbronc
Tomah WI
OK I have a 76 with a manual column I want to change to smooth. How much shipped to 54660.
Status
