5.0 efi engine bay pics!
JHolloway
Acworth/Kennesaw, Ga
I would like to see what the efi engine looks like from different builders. My project is in the works. Would like to see a variety differing in color of the engine block,intake etc. Just looking for ideas!
Mountain Ram
Recovering Masshole
Abingdon, VA
How not to do it...
Done by PO- I have alot of work cut out for me. Once I get it running right- I will start hacking away at the spaghetti wiring.
Good luck.
TD
browngr5
Eagle, Idaho
This is my 75 with a 1987 Lincoln Town Car 5.0. I had fuel delivery problems on hot days so I've deleted the low pressure fuel pump and moved the high pressure pump behind the selector valve next to the aux tank. It's much cleaner and runs extremely well, even on 100 deg days and stuck in traffic.
ljspop
San Marcos, Ca
I'm in the same spot. Think this is what I am going with:
I'm not looking to make mine super pretty tho. It's a driver.
Zillacon
Hackin Away!
No hood issues with the GT40 upper? I'm getting ready to do the same thing and was wondering if it would fit under the stock hood.
I have a 1" BL but also raised the motor 1" so I could still use the factory oil cooler so it should be damn near the same with no BL and no MML. I did have to hack down the oil fill tube as that did hit. I have cleaned up a lot of loose ends and will repost a pic soon.
Viperwolf1
electron whisperer
Same thing under my hood. Same BL and taller mounts. I used the mustang valve covers so I didn't need to mod the tube. PS reservoir will need to be moved down and back though.
NYLES
was about 1/2 done w/ efi install
