Auxiliary tank filler vent hose
Jeff76
Alpharetta GA
HAving trouble finding a 90 degree auxiliary tank filler vent hose. Turns out the PO installed what appears to be 5/8" straight fuel line, and this cannot make the 90 degree turnout necessary without kinking. Result is the inability to fill the auxiliary tank on my '76.
Any ideas on where to find one of these? Looked at JBG and Tom's to no luck. NAPA only has straight hose, and the parts guy could not think of an alternative. Picture is the one I pulled off.
broncomatt
My suggestion is to get a copper 90 and use a short piece of fuel hose to the 90. Should fit.
Jeff76
Jeff76
Alpharetta GA
This is what I used on my '76 when I had it. I didn't recall it being a 90 though?
http://broncograveyard.com/bronco/i-10255-vent-hose-auxillary.html
Not sure what that is, really. If its 3/8" or smaller, it could be the emissions breather hose that runs to the charcoal bottle. What I am looking is 5/8" and goes from the tank to a hole in the filler tube to allow air out while you pump gas in. The way mine was kinked, it was almost impossible to fill the tank.
Jeff76
Jeff76
Alpharetta GA
Yes, that is a good idea, and it should work. Was trying to keep it simple, though. I was actually surprised when the guy at Napa said he did not have a 5/8" fuel hose with a 90 degree bend in it.
g8rb8t
Yeah, that's the vent hose pictured that I used from tank to filler neck vent. That's not the charcoal bottle one. If I recall correctly it's 5/8" (almost positive).
Jeff76
Jeff76
Alpharetta GA
Knew I'd remember it...here's where I asked the same thing, looks like I used 5/8" from Napa not the Graveyard one:
http://classicbroncos.com/forums/showthread.php?t=147906
OK, Thanks. I found a picture of another install somewhere, and it looks like they used a straight line as well. I'll try to get a slightly longer hose length, and see if I can make the turn without putting a kink in it. Thanks again.
JefeAZ
Tucson
Just finished my aux tank install and I have the same exact problem. It kinked but not too bad. Thought it would work but cant give the pump more than a 1/4 pressure without gas trying to come back up the neck.
A braided/pressure rated fuel line would work as it will not kink but the problem is cutting it to length and getting it on the line and tank nipple. If you can easily collapse the line with your fingers dont waste your time. No matter what length you cut it to it will kink
I like broncomatts idea and may try that. Ill put a 90 on the filler neck and run a straight hose off the tank. and of course paint it black...
Jeff76
Jeff76
Alpharetta GA
Just went through the same process. While the picture I posted makes it look easy, the way my tank / vent hose works out it will not run the angle with out kinking. I bought a copper 90, but can't make myself install it. Just seems like a problem waiting to happen.
Found this at Autozone. PVC hose exact size and shape I need. Anybody have an opinion it this would hold up the the demands of the aux tank vent hose requirements? Would it deteriorate with the gasoline exposure?
Hozr
Oly, WA
silicone heater bypass hose or a pice of wire reinforced fuel transfer hose.
JefeAZ
Tucson
That piece might work. Put it on the filler neck side as high as it will go and connect it with another 5/8" straight piece. Whatever you connect them with cannot severely reduce the inner diameter of the line though. If it works, only the air that is being displaced in the tank will come into that line
Dorman makes these as well(Part # 800-038):
Should be able to get an 11/16" line on there...More flow the better not sure if anyone sells that though. 3/4" would be too big
Woops I read that as PCV thinking it was rubber. Should be fine according to these guys:
http://www.jenseninert.com/chemical-resistance.htm
How are you going to connect it to the metal vent line though?
Jeff76
Jeff76
Alpharetta GA
It is Rubber. I put it on today, and it fit perfectly. Tight fit on both sides, as if it were made for the application. Still not sure if it will handle the gasoline over time, but it looks slick. I'm going to run it, but I've got some work to do before I'm ready to put any gasoline in that tank though.
Jeff76
Jeff76
Alpharetta GA
That is a PCV piece. Looks like your box was printed wrong lol
http://www.dormanproducts.com/p-32423-46025.aspx
That piece was long enough to reach the tank? How much was it?
$12 here, free shipping: http://www.amazon.com/Dorman-46025-PCV-Valve-Grommet/dp/B0065V2YPM
You are correct, its a PCV replacement. I found it on the shelf at Autozone, and it was $12. It fit exactly the angle i needed between the tank and the filler vent. No kinking because it was the perfect shape. One side seemed to be slightly smaller diameter than the other and I used that side on the tank. Slight touch of petroleum jelly, and it slipped right on both sides without removing the tank (again). Standard hose clamps both sides. I should have taken some pictures before I left the shop. I'll post some tomorrow.
Sac '68 sport
Orangevale
I just used fuel line from Napa. It's pretty stiff compared to what I've got from other places. My problem is actually on the other end where it goes up to the top of the filler neck. I can't get the stupid thing on without it either kinking at the top or sticking out in the wheel well. I think I'm just going to use a filter up at the top and zip tie it to the filler up near the top.
Jeff76
Jeff76
Alpharetta GA
Here's a pic of the PCV hose installed as the aux vent hose. That loose vent hose in the way of the clear shot is from the rear tank. Should have moved it before I took the pic. Sorry.
Jeff76
Jeff76
Alpharetta GA
That's the problem I was having with standard fuel line. It would kink trying to get it to be malleable enough to make the 90 degree turn necessary to connect to the filler vent. That's why I was looking for alternatives.
BronCowie
Old Timer
Vancouver, WA
Just installed a new aux tank and filler tube. The vent tube is kicked out a bit so the hose bend is only ~30* so no kinking issues here.
