Trac lok rebuild instructions and tips
Timmy390
Conway, AR
I came across a used trac lok unit yesterday however it will need a rebuild of the clutches. I’ve done some searching and can’t seem to find a detailed tech article or instruction guide on how to rebuild one.
I’ve never been inside of one before so I’m reaching out for some help. Are there any special tools methods I need to know about? I read some place to “soak” the clutches before install?
Are the spider gears the same in an open diff vs. a trac lok unit? If you had an open with good spider gears could you swap them out into a trac lok unit if the ones in the TL were bad? Just asking...........
Tim
broncnaz
Im not 100% sure but I think the spider gears will swap over. Side gears will not well pass side might.. Other than Ford sevice manuals I dont know of any other instructions out there but its really not that hard just reinstall any shims that were in the unit before.
Ford did have specail tools to check the clutch pack thickness but I've never been able to find one.
All I can suggest is replace all the discs and steels replace the preload springs and thrusht washers for the side and spider gears and you'll have a unit thats as good as new. Only other tip would be that before your tighten all the ring gear bolts down install the axle shaft in the clutch hub side to make sure that the clutch hub and side gear splines match up then you wont have any issues reinstalling that axleshaft after its all built.
OX1
If your just doing cleanup and clutches/springs, here are some pics, this is a 31 spline unit.
broncosbybart
as said, they are easy to work on. spring pressure holds the 2 case halves together. i used two 7/16 bolts and nuts to keep the halves pressed together (through the ring gear mounting flange) while removing and installing the 2 phillips head case screws. this relieved the pressure on them, making them a lot easier to get in/out.
in the pics above, OX1 is using vice grips to do the same thing. you do have to soak the fiber clutch discs in gear oil before installing them. they would be way to grippy if installed dry.
Timmy390
Timmy390
Conway, AR
Thanks everyone for the advice tips and the great pic's. I'll update when I get the job done.
Tim
Timmy390
Timmy390
Conway, AR
The used "trac lok" tuend out to be a used "equal lok" unit that's seen better days. Case has been busted and welded back together and the gears were eathen up too. Not to mention the clutches were junk.
Passed on the unit so guess I'll buy a new one unless I find a used one soon.
Tim
Oatmeal
FYI, Trac Lok is a Dana/Spicer name, Ford 9" LSDs were called Traction Loc
Hans
Timmy390
Timmy390
Conway, AR
Well I feel like I hit the lotto but an idiot at the same time.
I disassembled my third member completely yesterday and put all the parts in the parts washer to let them soak. Once I removed the ring gear I could tell the “open” diff was really a 4 pin trac lok. I was very confused because this diff has never locked up in the 17 years I’ve owned the Bronco. When I took the unit apart, there was no clutch material left. It was all gone but for just a small strip on the first clutch. What was left was hard and brittle.
So looks like I have now educated myself on open and posi diffs. I’ll be ordering a clutch kit today.
Any idea what would cause this kind of ware? This rig sees less than 1K miles a year. My guess is no friction modifier in the gear oil?
Tim
turbotim2
____________
I did the same thing, drove my Bronco for years without noticing any lock up. The clutches just don't stand up to years in service even if you don't drive it a lot. I rebuilt mine and it locks up now, even just pushing the rolling chassis around (havn't finished the build yet).
OX1
Tim
Driving long distance with one tire severly underinflated (before you owned it).
Madgyver
Bronco Madman
where do you get the rebuild kit for the trac-lock? new clutch packs?
Timmy390
Timmy390
Conway, AR
Getting mine off ebay. Dude has clutch kit, friction mod, ring gear bolts and housing seal for $75 with free shipping. You can also get them from JBG and I expect all teh other parts houses has them too.
Madgyver
Bronco Madman
ebay seller's name or link to ad?
JBG shipping costs to me will be 1 to 1 of the price of anything I try to purchase from them.
Timmy390
Timmy390
Conway, AR
Just seeing this. I'll at work but will get that info for you as soon as I get home this afternoon/tonight
