Jeff's lists this as correct for a '72 Dana 44 front axle. All my other searching only shows it for 78-79 Broncos / F150s. Anybody have a solid confirm or deny on using this in an early Bronco front diff? Obviously Jeff's is closed until Monday. I realize its a 4-series diff, not sure if the high pinion / reverse rotation deal affects usage. I have a '72 Dana 44 with factory Trac Lok (per the numbers on the axle tube) that has some binding when turning the yolk. This is with the axle ends straight, so the binding isn't from that. Mostly moves smoothly, then gets rough. It didn't have a vent tube screwed into the housing when I got it, so it had some water in it. I have not disassembled it yet. I was looking to rebuild the Trac-Lok, but the only kit I could find was like $650, and this diff at Jeff's is $250 for the whole thing.
