- Sep 7, 2006
- 2,984
Well I finshed my 2000 Explorer OBDII engine transplant. I stated I would do a write up on it so here it is. Hopefully this will answer a lot of Q's all of you have and put a stop to the myth that its too difficult to do, in my opinoin its no more involved than doing the 89-93 stang 5.0, I'm sure will some will argue otherwise. However there are few things that will make it much easier.
1: You will need the complete running vehicle. When you purchase it, drive it and bring it up to operating temp then check for codes, yes you are going to have to purchase a scanner but you are going to need one anyway, this way you will know what you have before you start, which will keep you from guessing later when you have finished and fire it up. I see them all the time on CL for 2K or less with low milage and you can always scrap what you dont need and get some of the money back. I will list the other parts you will need from the Explorer later.
2: You must be able to read a wiring schematic and understand it, if you are not too comfortable with this I'm sure members here can help you along. I will post the schematic I have in the pics, which will be all that is needed, or at least thats all I needed.
3: You are going to have to do some fab work so if you can weld thats great if not you better get to know someone who can. There are 3 things that will need to be addresed, well 2 for sure, the 3rd being the stock Bronco rear tank. I modded it so the Explorer fuel pump would fit in it, you can buy one from the vendors if you like but it will prob need to be modded so the Explorer pump will work.
4: For the PCM mods contact Rick at http://www.amazonracing.com/contact.html
These are the items I had removed from the PCM
A: PATS, I originally was going to use this and I wired up for it but later changed my mind. I didnt want this thing giving me probs when I'm in the middle of nowhere hunting and its 15* outside.
B: Tranny, I'm running the c-4. If you plan on using the stock 4R70 then you will want to leave this unless you are going to use whatever all the other members are using then it will need to be removed. However if you plan to use the stock harness to control the tranny you will need to look at how you are going to incorporate the stock shift leaver to the shift range sensor from the column shifter on the Explorer, I'm sure it can be done I just didnt look into it.
C
ost Cats unless you need to run the cats, I dont
D:EVAP Emissions, there are 3 codes he could not remove with the chip I supplied however they do not effect the engine performance at all, they are as follows:
1: EVAP purge control valve
2: " pressure sensor
3: " vent control
these are all fuel tank emmisions, no worries
Ok I will throw a couple of pics on here to show what the final build looks like and tomorrow I will continue on
C
3: " vent control
