Big79
This is a part out truck and it WILL be going to the scrap yard this up coming Saturday. So if you want parts off of it I will need to know befor Friday.
Stock 351m(turns over by hand but starter won't crank, don't know if it runs or not).
C6 and NP203 Tcase(don't know the status other than was told it works fine)
Danna44 with all the steering components and brakes,does not have locking hubs!!!, has lugs(full time)! Seams to be operating correctly
Rear drive shaft and 9" rear. Complete and seams to be working correctly also.
Also the 4x4x2 steering box is complete and is not leaking!
The grill insert is in ok shape,most trim pieces are ok(tight side of truck was hit,so might not have good body parts. Again, this will go to the crusher so if you want anything let me know ASAP!
405-481-9658
405-481-9658
