Ok, yes I have all that and a bunch more, Just want to make sure people know this is just the cable, I do not have plugs(ends). How i set up mine and others is 50 feet hard wired to a box or panel, with a box, with a welder outlet in it. Best part is if you move, or want to weld at another house(buddies) it can all be taken with you. If you need help setting it up I can talk you thought it. This cord is heat, water and oil resistant. they use it alot on construction sights as temp feeders. At work we run over it with the fork lift all the time. I have lengths up to fifty feet plus I think that is all I can fit in the flat rate box.
I do have a pay pal. how ever I am leaving for vegas on tuesday, and will not have time to ship anything, so i will get them ready to go on sunday when i get back, and then get with you guys to settle up.
rj robin If I remember you bought a plasma cutter like mine, which I use the same cord and can cut where ever also.
Brian i will pm you my address so the check can ship while I in Vegas or you can wait your choice.
