This adapter kit is made so you can put a Coyote engine in your Bronco and be able to use your small block transmission. Yes you read that right, you can now bolt up a small block C-4 C-6 AOD or 4R70W transmission to a Coyote 5.0L engine. This can save you thousands of dollars on a Coyote conversion. Now putting a Coyote in your Bronco is close to the same price as a good rebuilt small block with EFI. Part #16-00521
http://www.bcbroncos.com/store/product_info.php?products_id=2393
