So the wife and kids left this morning to go to her moms, so I started my full width swap. I don't wheel a lot but I hope to get to the point where I have a capable rig eventually. I have a 67 with the stock Dana 30 and a small bearing 9 and suspension that was shot. I was not going to dump any money into those axles so why not go full width. All of the suspension components came from Wild Horses.
I ended up getting a set of axles out of a 79 big Bronco that were "rebuilt" so after I got done going through them and spending more that I wanted, I now have a good dependable set of axles. I plan to upgrade the axle shafts and install lockers eventually but its not in the cards right now. I ended up using the James Duff extended coil buckets and am very pleased. I now need to finish the steering and the track bar. I also installed the F250 shock mounts while I was at it, I cut the stock mounts and extended them up.
Once the axles are done in will be building a set of Lars Bars and then measure for front shocks. I pan on installing the rear axle tomorrow if the weather holds up.
Here are a few pictures. The axles needs to shift to the passenger side about a 1/2" to center it but looks pretty good.
Here are a bunch of pictures.
