brewchief
- Feb 11, 2007
- 871
I'm planning on build a hi pinion d44 for my 74, I have a 78 f250 housing.
I was originally planning on building it early bronco width but have some concerns that it might have oil pan clearance issues at full compression, I don't really want to go full width but was thinking of something in between. IIRC an early bronco axle is 7" narrower then a full width, instead of narrowing it the full 7" maybe building it 3 or 4 inches narrower would work, that should give a bit more oil pan clearance and I could probably get away with not building a wider rear axle right now as well.
Suspension is probably going to end up 3 link with coilovers(and hopefully a spot for future bypasses) although I haven't ruled out radius arms completely yet.
Anybody done this? Bronco sees a very small amount of street driving, mostly just sand dunes.
Sent from my SM-T510 using Tapatalk
