jcb9089
- Feb 22, 2007
- 510
1976 Ford Bronco project.
302 with 4 speed toploader, Headers, dual exhaust with flowmaster mufflers, Holley 4bl Carb, Mickey Thompson Valve covers, power steering (rebuilt West Texas Offroad)/pump/hoses, Dana 44 with disk brakes. Dual front shock mounts, 2 inch lift. Engine/trans rebuilt RV Cam; less than 20K miles. Radius arm arms/C - bushings have been replaced.
Comes with a nice grill, complete dash (matching glove box door/title), original wiring harness, good hood (no rot), 23 Gal tank, windshield frame, steering column, doors (solid but need skinned), Halogen Headlights. Duffs 70/30 shocks, Duffs 4 speed shifter, set of alloy wheels. 3 – 31” Firestone Destination A/T tires with 75% tread, the 4th tire has a sidewall puncture. New: bikini top, Gorilla Warflare set, Body mount set with hardware, 3 pt seat belt kit, nice stock seat set, rear seat frame powder coated.
Does not come with tailgate/top, distributor, bumpers, and brake booster/bracket. Needs a front wheel hub on pass side. The tub on this is in good shape: needs outer rockers, but inners look ok, small hole in driver floor, lower door posts need patched, upper inner fenders need patch, rear door strikers are solid along with the qtrs, no rot from floor pans back.
History on this Bronco. I owned it and sold it, but it came back to me after the new owner rolled/ruined tub and top. I picked it up with intentions of cutting off the rockers/lower door posts to install rock skis and then running bikini top and door inserts. I have 2 other projects and don't time for this one. All in all this truck has good bones and a great restoration project.
