dgold_881
- Nov 24, 2009
- 368
I've done my search on here and seen that some have had issues with the M/C marrying up to the hydro boost and using a spacer.
1. Is that due to the o ring around the bullet insert that's used to make up the distance for the push rod to apply pressure?
2. Can I just take off the o ring drop it in and call it done.. no spacer needed?
3. If I mount this unit directly to the firewall the push rod is to short do they make an extension or do I just cut it and weld one in?
Thanks for any input
Added info I'm running 4 wheel disc brakes full width 78-79 bronco axles
The M/C is from a corvette
Hydro boost GM Astro Van
