CoronaDog
Hey guys, first time posting, hoping to get some good advice on this one.
I bought and started driving my bronco back in April. Haven't had any troubles till this week. I noticed that the while driving, the engine started to sputter, almost as if not enough fuel is being delivered no matter how hard I stepped on the pedal, but eventually, with either hard pumps or constant stomping, it would correct itself and run normal.
This began about 7 days ago, but 4 days ago, I sputtered out and I could not start the engine again. It cranked, but would not spark. It always seemed to take a while to start if this matters.
Engine: 302, not the original, from the serial numbers indicate it is from 1980 year manufacture. edlbrock carb.
I decided to replace the plugs, wires, dizzy, and coil. I ended up taking the dizzy and coil back to AZ because the electrical connections did not match what I had, but I keep the Accel plugs and wires.
My question is, am I on the right track? Plus, what are the suggestions for new dizzy and coil? Is upgrading to an ignition control system the best idea?
Thanks!
Gene
Thanks!
Gene
