Explorer PS Pump PSI and FLOW modification
chuzie
Seems the opinions are 50/50 when it comes to the capabilities of the Explorer power steering pump and it's ability to effectively turn large tires, handle ram assist, and actuate hydro-boost. Personally, I am running 35" tires and an 11" ram assist connected to a 4x4x2 box. At idle, I have to work way too hard to turn my wheels. This not only sucks in the parking lot but especially on the rocks.
My research on the matter has yielded an array of potential options.
Some include:
1.) Reduce PS pulley ($75.00 from Drivenautoparts.com)
2.) Swap the crappy pressure adapter to a Lee's adapter (~$20 from Lee's Power Steering)
3.) Ditch the Explorer pump and replace it with a modified Saginaw pump and modified Explorer bracket. ($370 from Lee's)
4.) Send the Explorer pump off to Lee's and have them modify it for higher pressure/ flow for about $130.
So these sound like great options so what is my problem?
Well, I am not a fan of aluminum pulleys. They make my belt squeak!
The pressure adapter is a non-issue for me since I am running the stock Explorer pressure hose.
I am not made of $$$ because Uncle Sam is broke!
I seriously considered option 4 but the folks at Lee's convinced me that the modified pump would be maxed out with my setup and even then it would only put out about 1,600 PSI.
I recently stumbled upon a couple of old threads, here on classic, about the pump issue and found that some folks tried to stuff the internals from a 2004 F-350 Super Duty (6.0 diesel) into our Explorer pump housing. Just to be clear, this was not my idea. I am just gathering all the info into one place. I think Lars deserves all the credit. I would also like to add these numbers have not been personally verified so please feel free to provide your two cents for corrections.
Those threads are:
http://classicbroncos.com/forums/showthread.php?t=131835
and
http://classicbroncos.com/forums/showthread.php?t=189786
Lars successfully performed the swap with no issues and recorded 1,800 PSI (1,300 PSI was recorded prior to the modification) without having swapped the SD pressure relief assembly.
Scrapman1971 stated the SD pump flows at 3GPM vs the 1GPM of the Explorer. I have requested his source material for those numbers.
So, we have the ability to increase PSI and GPM with a little labor and roughly $50 in parts ($25 for pump and $25 for seal kit)? This is a no-brainer, right?
This is Lars's picture of the Explorer pump (left) and SD pump (right).
attachment.php
The case differences are obvious but look at the pump sizes. That is what Lars was aiming for.
During my modification experience I noticed that the guts looked almost identical between the SD and the explorer so I am unsure how this modification makes the increase in pressure and flow but then again, I am just a stupid pilot (glorified bus driver), not an engineer.
My results: Runs great. No leaks. I can finally turn the wheel with my pinky from stop to stop without any hesitation from the system. I still want to put it in 4-LO and get the wheels against an obstacle to see how well it does but the preliminary results are positive.
Parts List:
96-01 Explorer PS pump ($0 if already installed)
03-05 SD 6.0 diesel PS pump Ford P/N STP-102-RM ($25 at junk yard) I would recommend 2004 since they started using this pump in the second quarter of 2003. Not sure if there are some oddball variants out there.
Seal kit ($25 at NAPA NPS 7382)
Phase I
Remove and drain the Explorer pump.
Remove the pulley.
Locate the retaining ring access hole and remove the retaining ring.
Before removing the back cover, I suggest cleaning the debris to prevent unnecessary contamination. Remove the back cover keeping in mind its crusty old O-ring may make it a little difficult.
Remove the pressure plate.
Remove the retaining ring on the shaft that retains the rotor and shaft but DO NOT remove shaft.
Reinstall the pressure plate. This will help to retain the rotor fins.
While holding the pressure plate in place, turn the pump upside down and allow the pressure plate, rotor, cam ring, and two dowel pins to slide out together. If the vanes fall out, no biggie. I will tell you how to reinstall them later.
Remove the shaft.
Remove the thrust plate and thrust washer. Notice the concave side of the thrust washer is facing the thrust plate.
Use a seal puller to pull the shaft seal from the front face if so desired.
Remove the pressure relief valve assembly. This picture is misleading. The pressure relief valve does not rest in the plug; it is backwards. I threw it together for the picture and failed to realize my mistake. Whoops!
Remove the plug from the unused pressure switch port.
Phase I complete.
Phase II
Dismantle the SD pump the same as above.
Here are the two cases side by side with the SD on the left and Explorer on the right. There are two cast pillars on the lower wall in the Explorer case and a single partial pillar on the SD.
I used a Dremel to match the Explorer case to the SD case as much as possible.
With the cases matched, I used brake cleaner and compressed air to evacuate all the contamination I introduced into the case.
Phase II complete.
Phase III
Time to cram the SD guts into the Explorer housing. Installation is the reverse of removal. This is a great time to change all the seals.
A few items to note:
Make sure the convex side of the thrust washer is facing the thrust plate.
Lube all the seals.
Ensure the vanes are installed properly if they fell out. The picture below shows how the vanes have a smooth side and a partial glazed side (caused by wear). With the rotor facing up (identify UP by the subset in the center for the snap ring). Place the vane at the 9 o'clock position with the double panel side facing you and the smooth side facing 12 o'clock. This is how they came out and is how they should go back in. The directions say to make sure the rounded edges are toward the cam ring but the edges of these vanes look the same on both sides in my opinion.
Here is an IPB and instruction sheet that came with the seals. Good for reference and sanity check.
Seal everything else back up and install.
Doneski.
:cool:
Enjoy.
BroncoBrandon
This is great!
I have been looking for and upgrade option that does not cost an arm and a leg.
Rox Crusher
Chuzie, what reservoir set up do you have ?
I like the idea of doing this upgrade but am curious if the increased GPM might create a fluid supply problem if the reservoir and hosing isn't optimized ?
chuzie
chuzie
Stock reservoir. I need to get out there and monitor the fluid level under high demand. Will report back tomorrow but I don't suspect it will be an issue.
I imagine this could potentially be a concern for hydroboost + ram assist combination but I have no experience with HB.
Viperwolf1
electron whisperer
Good work. Spruce this up a little and make it a tech article. I suggest adding a part number for the SD pump (a lot of people prefer new parts), maybe highlight the areas of the explorer housing that were modified, maybe a bigger readable pic of the instructions (or type them out).
chuzie
chuzie
Thx. Suggestions implemented. Gonna wait for the dust to settle before I send it to Jon as an article. Want to make sure the facts are verified accurate and sources correctly identified. Plus, I want really give this pump hell in April at the Meet + Greet in NC. The rocks will surely put it to the test.
KyleQ
Nice article - don't forget about PSC, they offer a bolt in TC style solution and beefed up pumps with nice upgrades as well.
broncnaz
In the end the only differance I can see is the mod to the housing(which could increase flow) and if you swap the SD relief/flow control valve in.(which probably increases pressure and flow to a degree) Unless there is a actual differance in the rotor and vane diameter between the explorer and SD there is no gain in swapping them. But flow and pressure are also tied to RPM. At low RPM you have lower flow and lower pressure Higher RPM the higher flow and higher pressure along with more heat. MAX Pressure is really only increased by a stiffer relief valve spring.
Best bet may be to actually measure any differances between the SB and explorer pump internals. to really determine what the differances are. Only real issue may be figuring out the spring rate differanes if any.
Increased GPM and fluid level is not reallly a issue the fluid going out faster returns faster. So no change in fluid level. Resivoir capacity and cooling are more of a issue as the more flow the more heat same goes with more pressure is more heat especailly when your just driving without turning the steering wheel.
slow440
Ok, I just did this. There is a difference between the two housing internals. The gap between the rotor vein and the egg shaped hole piece is bigger on the super duty at the outer/longer ends of the ellipse. The bigger gap probably allows for more fluid flow. The pressure valve is also most likely different for more pressure. The Spring also felt a bit stiffer and had a slightly bigger wire diameter. I still shimmed it with a thin washer at re-assembly just for kicks.
mp
Austin, TX
I just got my pump back from Lee's (both flow and PSI upgrades). I using the Driven aluminum pulley and the Lee brass adaptor. I am still working on some other stuff and have yet to bleed and test the pump, but I hope the upgrades were not in vain and my steering improved.
KyleQ
Yeah - if the p-pump doesn't work out I'll look this way too.
ntsqd
heratic car camper
Upper SoKA
Minor addition: Tom Lee retired and closed the business. One of his long ago apprentice's started Power Steering Solutions (found on FB, net page is only a placeholder) and might be a source for continued Lee Mfg type support. I've not used him, but the couple reports I've gotten are good.
