Dbarnes72
Radiator is the Champion (new in box) 3-core for Early Bronco. It has a slight warp. (Maybe 1/4") Sent the original back and this one came back the same way. Maybe inherent in the Champion manufacturing process. 150.00 Standard Bronco in/out and Auto trans coil. Radiator SOLD
Core support from TBP. Slightly modified (hacked out) to fit larger body mounts. Radiator brackets installed. 130.00 obo Shipping may hurt you. It's not the pretty one with the factory look. Core support is OBO.
Used Rocker. Has holes from drilling it out but no dents/bondo. 45.00 Rocker Sold.. Thanks Jim
Aluminum water pump standard Bronco configuration. Superkooler pump from Tom's. P/N 6486. New. Installed but never ran. Reduced to 50.00
V8 radiator weld-on L brackets. New. 25.00
Stainless Steel 4-core radiator mounts. New. 25.00. Radiator mounts SOLD
Harmonic Balancer. 28oz 3 bolt for early 302 or 351. New. 65.00
Shipping on your dime.
