rhino2104
- Mar 2, 2006
- 801
I'm working on getting pieces parts together to swap a 4BT into my '76. I thought that I had it all planned out but I've found a couple of things and had a couple of ideas that are making me maybe change direction. The original plan was a 4BT, Dana 20, and an NV4500 transmission.
First, would a NP205 mated to an NV4500 fit in a Bronco? I mean, would it fit in the frame without massive fabrication work or clocking the t-case? I may have a lead on a running 4BT with the VE-pump (I'd prefer the P pump), NP205, and NV4500 in good order so that's why I'm asking.
Second, what about the ZF transmission? I know that a lot of people swap them into v8 Broncos with great results. Other than cost are there any advantages to the ZF vs. the NV4500?
Which route would you go with and why? Keep in mind that this is going to end up being my daily driver and it'll spend probably 95% or more of it's life on the streets.
