Building a rotisserie for a 66-77 Bronco
Crawdad
I am wanting to build a rotisserie to fit my 72 and 77 frame. I asumming both frames are the same. I bought 40' of 2x2x1/8" square tubing yesterday along with two short pieces of pipe that slide into one another. I have many pics of rotisseries but what I don't have is measurements. My thoughts are to fab up a "H" pattern for the base with a 4' width. On the ends will be 3' lengths, I plan to use 4 caster wheels on each corner. Here is where it gets sketchy. How high (throat) do I come up from the base? 36", 42" or 48"? Phase 1 is to have rotisserie fab bed enuff to handle the 77 frame. Once that frame has been powder coated I can remove it and move on to Phase 2. Eventually My plan is to rotate the 72 frame with the uncut tub bolted on to it. I will have to widen its stance and add more safety features so that I feel comfortable under it while I work.
Picture attached I believe is from a rotisserie built by Fordfan.
Any advice is much appreciated!
Matt
broncosbybart
I wouldn't want to use 2x2 for that. Tire carrier, yes. Rotisserie, no way. Judging from that pic knowing there is 24" between frame rails, my guess is you're looking at 48", prob a little more.
suthernboy
Greenville, NC
I would think the height of your "upright" would be 1/2 the width of a Bronco, plus whatever distance you want from the body to the ground when its sideways, minus the height of your base arms including casters.
I'd re-think the 48" base arm length, that seems a little narrow, I'd think more like 5 Ft. Although I've never built one, friends that have used square tubing for their uprights, one larger, one smaller, so one slips inside the other, then they drill multiple holes spaced 2 or 3 inch apart several times and use a 1/2 inch pin so they have some height adjustability. If you're only gonna do a Bronco, probly don't need that, but they do various vehicles and just make different frame adapters (Challenger, Camaro, Mustang, etc) for whatever they are working on.
bax
Old Member
do a search for redneck rotisserie
Datch
St Albert, Alberta
I built mine with a hydraulic jack at both ends, centered the pivot points in the middle of the body. I went with 3.5 square and 4" for the ends and 2" for the spreader tube. Works well for me.
Crawdad
Crawdad
Bax, I really like the plywood rotisserie. That was very inventive but I don't have a whole lot of level concrete.
Datch, I found some plans online that had some hydraulic bottles but I think that may be way over my head. If I did this for a living that would be essential.
Bart, 3/16" would have been best I'm sure. Most plans I looked at used that thickness. I did find some 3/16" tubing but there will be a good bit of 1/8" tubing.
Crawdad
Crawdad
Phase 1 has begun and here is what I have at the moment. The throat is 36" high, width is 4' and legs are 3' off-centered. Not the most level piece of work as it may be 1/8"-1/4" off, my semi-level concrete pad is to blame. I figure once I get some 3"-4" wheels on it that so t matter. But for now it's spot welded and awaiting final welding. I need to figure out the pivit point. I'd like to slide it onto the throat but I will have to think more on it.
At the moment I feel it meets my expectations for holding my 77 frame only. My powder later guy will like it as the rotisserie and frame should fit in his booth. Once I get it back from the powdercoater I can swap out the 77 frame for my donor 72 frame. Remove all the non-vital parts and weld on some 6-8" pipe like what Fordfan did. Eventually I'd like to put my tub on that frame and get to work. But in order to do that I will beef up this rotisserie a bit more with thicker metal and a wider stance. This extra beef I "hope" to bolt-on and not weld. I'd like to make this thing a convertible so to speak. Take off the bulk I don't need, add on when I do need it. Stay tuned and we will see! Matt
Crawdad
Crawdad
Purchased some 8" solid rubber wheels. Tack welded on the pivot point along with the swing arm. I'm in the process of drilling out all the holes on the swing arms but my drill pooped out on me. Phase 1 is nearing complete.
Crawdad
Crawdad
Right now it's 4.5' wide. Bronco frame apprx 13' so I expect about 14' wide between each pivot points.
Crawdad
Crawdad
It's a lil hight but the swing arm will be adjustable.
Crawdad
Crawdad
Did the finished welds this past weekend, brushing on some primer really thick. I'm pretty close to installing the 77 frame. Hopefully this coming weekend I will be ready. Bought some more metal today to reinforce it for Phase 2. My PowCon is doing well but will be needing some more gas as I'm about MT. Hope yaw are doing well.
Crawdad
Crawdad
I have about 99% of phase 1 complete. I need four tabs to make out of some 3" angle iron this weekend. Once I get those bolted on I will paint the whole thing. I did put the 77 frame on it and I like it a lot! It is a bit high but I will change that later on when I put the 72 frame and tub on it. It's a bit of a bear to turn but that's bc it's not concentric. But for now I like what I built.
