jimschulz
I have an issue that has reared its ugly head with my FiTech system. The system starts and runs flawlessly for varying amounts of time and then will start to cut out. When this happens the controller display freezes with the RPM stuck at 59000+ and I have to reset the display to see real time data. It will drive fine at times and other times it will cut out over and over. Contacted FiTech and they thought it was a low voltage condition. I put a meter on the keyed circuit and there is no voltage drop untill the alternator slows from the cutout condition , and even then it only drops from 13.8-9 to 12.0 (Going from Alternator to battery voltage). I am thinking the unit has a bad ECU that just cuts out. There is no codes being spit out either. If anyone else has had this issue let me know. Thanks!
