Revell build thread,post your status too
Skiddy
Well I am going to call this frame off Revell, I know I did put a lot of thought into it%)
first I got the long block done, went with a pretty much stock 5.0 roller with a mild cam, and painted ford blue. I had the 3 speed tranny rebuilt while I was at it.
next I installed the intake manifold, I used some studs to align the manifold to the heads so I was sure the gasket didn't slide around.
installed the timing chain, I went with the double chain as I heard good things about them. installed the cover and water pump. so far so good.
here is where I ran into a problem. I think they sent me the wrong bolt and spacer for the alternator, couldn't get it to line up:mad:. I'll go out to the shed tomorrow and see if I may have another lying around. Has anyone had this issue with theirs?
I will rebuild the transfer case. Does anyone recommend a good rebuild kit?
Would like to hear how some of ya'lls are coming along.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I suck at model building. I've always sucked at it. Even the snap together ones I had as a kid didn't come out right.
Mine will be staying shrink wrapped in the box and displayed on the shelf with other Bronco memorabilia as is. Looks good doesn't it? ;)
399strokerEB
Wasilla, AK
So far I have the rear seat re-done, and started on an Aod swap. Still need to find a power steering setup.
half cab
Guru Bronco
Working on my shop right now but I've lost some of Jr's Lincoln logs and building blocks so I'm at a stand still at the moment.:p
stout22
Athens, AL
Purchased most of the paint supplies. Not 100% on the exterior color, may need to start a poll. Not sure of the tire/wheel package - may need another poll. Carb or EFI - another poll?
sriha
I need to finish building my rockets before I can move on to the Bronco so it is currently in pieces. What will be your method of painting? Is it worth it to get a good spray gun?
tasker
all knowing of nothing
NH
As if i needed another frame off....here we go again! Block has been hot tanked and built....have a 427 from a a fairlane that may just find its way into the Bronco instead! Frame is painted and almost a rolling chassis at this point
daddycreswell
Lebanon, TN
You should have braced the body, it's going to be a pain in the rear to get it back into square.
No Hay
Not much custom here. More of a survivor ;D
canadian broco
I spent a few days over the Christmas break and did my first model kit in over 30 years. It was a fun project and my youngest son worked on a 66 mini at the same time. I had some left over paint from the early 80's, and used a brown to do my seats. It was thick as molasses, but seamed to add depth (lol). Anyways, here is the result so far (still a few details left to do)...
Dlish
those complete ones look great!
I opened the box, looked at all the pieces, and closed the box.
Skiddy
Skiddy
That's pretty cool, you have the same mufflers as I do:cool:
got the frame back from the powder coater, resealed the transfer case. I am still not sure if I want to do a luber or just stock hmmm. then wonder what lift what tire and who's to buy. dang more decisions and more research I guess
every ones are looking good
Skiddy
Skiddy
My steering box is leaking right outta the box :D
Well crap, maybe you can send it back to the vendor? if they will not take it back let us know who the vendor is:p
here is my current state, I know we all like pics;D
CopperRanger
Nice job, you have given me some inspiration to get going on mine.
Slowleak
Georgia
That looking good Skiddy! I like how you already have a sheet of cardboard under it.... :)
broncoman1972
I just noticed they have glass packs. Awesome!
