Took the hard top off years ago, and never looked back.
You have two really good options with the mass produced soft tops. I say that because there are some really nice upscale ones too that you can order, but I don't know much about them other than they cost more and they're super cool.
However your two cheaper options are the Rampage/STC/Kayline top or the Bestop Super Top. I have owned either, and they each have their redeeming qualities.
The Rampage top is less expensive, it sells for around 550 or so for the complete kit that includes hardware. It also comes in a bunch of different colors and fabrics. The nice part about this top is how it goes up and comes down. It uses a flat bar that hooks to the front bow and when you release the pressure from the top, the front just pops off, and you can fold it back. Very nice! One thing that it does require is the wiper motor drop bracket and this precludes you from running the motor cover and visors.
The Bestop has a different design, and a taller stance. It is more expensive around 830.00 bucks, and it only comes in black. I like the fit and finish the Bestop (that is what I run), but it is more difficult to take up and down. You have to slide the front of the top with a sewn lip into a channel in the front bow, and this can be time consuming and annoying if you're in a hurry. It does however have a taller riser than the Rampage top, and does not require the drop down bracket for the wiper motor. You can also run the factory wiper motor cover and visors, but you have to cut it back to fit.
I have the Bestop because I like my visors and motor cover.
Which ever you decide to go with, ask lots of questions about how to install on here or elsewhere before attempting to do so. Both of these tops can be impacted in terms of sealing and appearance if they're not installed correctly, so take your time when doing the install.
Good Luck
Rich
