    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
SOLD Original 66 U14
Status
Not open for further replies.
West Tn Dawg
BULLDOG
Kenton
Still holding at $30k. I will not pay the ridiculous new photobucket prices!
I can e-mail pictures.
Selling the wife's 66 U14. Unbeleivable 66, that I don't want to sell, but she wants an automatic with the power options. I got what I want, so I guess she should get what she wants.
It was an award winner this year at Super Celebration.
Here is a link for pictures, I hope works.
http://s34.photobucket.com/user/WestTnDawg123/slideshow/66 U14
Build Notes
This Bronco is very period correct. Please read for details of the restoration.
• The Bronco was put together with all the original body panels
• It was built to be as close as it was the day it rolled off the assembly line as we could.
• DISASSEMBLY:
• The body was removed from the frame and placed on a rotisserie.
• All rust was removed and panels replaced.
• Drive train was completely removed from frame
• It was a 100% nut and bolt restoration. Every single nut and bolt was removed and replaced with period correct nuts and bolts.
• PREP:
• All seam sealer was removed, and then every body part was media blasted on all sides
• All pieces were primed 100%, and seam sealer reapplied
• The underside of the body, engine compartment, and the front and rear fender wells were repainted while on the rotisserie
• The frame was pressure washed, sanded, and wire brushed
• Frame had 1 coat of POR-15 and one coat of POR-15 chassis coat applied
• Start reassembly
• Engine, Transmission, and Transfer case were completely rebuilt and reinstalled in the frame
• The body was reinstalled on the frame with all new mounts and bolts
• It was returned to the body shop for final paint to the original color, with base coat clear
• It was the color sanded and polished to a flawless mirror finish
• Engine
• The engine was completely rebuilt, bored to clean up
• New pistons and rings
• Crankshaft turned and new bearings installed
• New solid lifter cam, lifters and timing chain
• Valves were ground and new seats installed
• New springs, retainers, gaskets and seals
• The carburetor was rebuilt
• New oil pump and water pump
• TRANSMISSION
• Transmission was disassembled
• New shift arm seals were installed
• New synchronizers, bearings and seals
• New diaphragm clutch
• New throw out bearing
• Transfer Case
• All new seals and gaskets
• D-30 FRONT END
• Completely disassembled and cleaned
• New inner axle seals, outer axle seals, u-joints, wheel bearings, spindle bearings and seals, and new carrier bearings
• New “C” bushings
• New radius arm bushings
• New trac-rod bushings
• Original Warn hubs were cleaned and re-installed
• 9” REAR END
• New axle bearings and seals, carrier bearings
• New factory Ford posi-trac clutch pack, new pinion seal
• BRAKES
• New brake pads
• New wheel cylinders
• All new springs
• New brake lines
• All drums were turned
• Final Assembly (Original Parts)
• Rare “Eye Brow” grill
• Fenders
• Hood
• Headlight trim rings
• Doors and door panels
• 1966 tailgate
• Inner and outer rocker panels
• Windshield frame
• Engine air cleaner
• Original Dash Pad
• Front and rear 1966 specific bumpers
• Heater and fresh air hose
• Heater duct hose
• Driver and passenger air box
• Original vacuum wipers
• Original jack and lug wrench
• NEW PARTS
• Front and rear stock height springs
• Shocks
• Stainless brake lines
• New master cylinder with new stainless flex lines
• Radiator
• Seat cover
• Bronco script floor mat
• Door seals
• Front and rear glass seals
• New wiper arms and blades
• Heater control cables
• Heater core
• Heater valve
• Battery tray
• Headlight splash guards
• Turn signal assemblies
• Tail light lens
• Front and Rear drive shafts and yokes
• New 13 gal fuel tank
• New fuel sending unit
• New fuel lines, tank to pump
• New factory correct fuel pump
• New fuel lines Pump to carburetor
• New fuel pump aux. vacuum line
• New distributor vaccum line
• OEM PARTS
• New factory correct FOMOCO script radiator hoses(period correct part numbers)
• New period correct Autolite white stripe heater hoses
• New Autolite script voltage regulator(period correct part number)
• New period correct Autolite script yellow top coil(period correct part number)
• Autolite plug wires
• New windshield washer bag and hoses
• Period correct ribbed engine and jack decals
• New period correct alternator junction box
• New horn
• New exhaust system
• Exhaust clamps stamped FOMOCO
• Period correct fasteners and clamps
• Autolite script alternator with part number and build date
• Fan belt with FOMOCO script and part number
• Autolite distributor cap with Autolite script
• New Autolite plugs(correct part number for year)
• New date coded battery cables
• New Master Cylinder and line
• New drag link (Stamped FOMOCO)
• New steering wheel and horn button
• Driver side air vent seal
• New Gel battery in period correct Autolite battery case, with correct part number.
• New Power King 7.00 X 15 MT – Bias Ply tires with matching spare
• Very Rare 1966 hubcaps that came from the dealer when purchased. Never installed until this restoration
1strodeo
Squirrel Watcher
Wisconsin
Hey Dawg, just click the red triangle on the left and ask Jon to move it, he told me that makes it easier for him.
Jeff
T-Bird
East TN
I saw this one at SC a few weeks ago, and it looks better in person. It is a top shelf restoration.
West Tn Dawg is a great guy who you can trust!
West Tn Dawg
West Tn Dawg
BULLDOG
Kenton
The May 2017 calendar model!
Thanks for the compliments everyone!
I just found out it made the Wild Horses Catalog too!;D;D
The wife is beating me at every car show we go to and now the calendar and the catalog!!!!!! I got to sell this thing! She is getting hard to live with!LOL
blue78
Huntsville
My god that is beautiful. Good luck with the sale, i'm sure it is going to be hard to see that beauty leave.
Jaxgtc
This is crazy but I was admiring your vehicle in the gallery earlier today! You should have no problem getting your price, that is one beautiful truck! Drooling like everyone else right now...
West Tn Dawg
West Tn Dawg
BULLDOG
Kenton
She is pushing hard for an automatic! Lowered to $30k. That will be the bottom dollar!
I'll just keep it and buy another one with auto.
LUBr LuvR
Now Ricky, you just can't go swingin' doors that wide......far too tempting!
Status
