New Name Build Thread: from "Obscure Machine" to "Bayou Hazard"
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
This is the second incarnation of trying to rebuild this ButtStank Bronco. I'm in determined mode.
Why a new name?
As it was known as The Obscure Machine, which is the old name of all the ButtStank on it - It needs a new name. But now my goal is Daily Driver. And, In the Bible, when someone received a calling, many times they were given a new name (Jacob to Israel, Simon to Peter, Saul to Paul, Abram to Abraham). So the Obscure Machine will be receiving a new name. Not sure what yet. But the build is now "Project Redemption"
1974 (not 73 Dennis!!!) 302, C-4
Work previously done before it was parked 4+ years ago.
  • 23 gallon metal fuel tank
  • new fuel line
  • Carter electric fuel pump
  • Edelbrock Performer Intake
  • Edelbrock Performer 500cfm Carb
  • H4 headlights
  • Front parking light lenses
  • Tail light lenses
  • Gauge cluster overlay (that quit working 4 months later)
  • Hedman headers
  • Flowmaster mufflers
  • Pipes exiting out each side behind rear tires
  • Front disc brake conversion
  • Power brake booster and master cylinder
  • Pertronix igniter
  • MSD coil
  • New wires and hoses
  • Saginaw PS pump
  • Tom's Bronco Steering Wheel
  • Actually bolted the seats in
  • New Track Bar and Bushings
  • New Tie Rod and ends
  • New drag link
  • Welded in bracket support to frame for power steering
  • 2" Body Lift
  • Warn Locking Hubs
  • Bikini Top
  • Destroyed the rusted hard top trying to make a safari top
  • Rebuilt the carb twice (from sitting without running for long periods of time)
  • Installed several security / anti-theft devices
  • Installed a Sea Blue Fuse Block for extra circuits.
  • New Driver Floor pan
  • Rewired most of the engine compartment
    • AND THE BEST MOD EVER! HOOD SHOCKS!!!
That's all I can remember
NEXT POST - What I've done in the last 3 weeks!
ObscureMachine
ObscureMachine
World Headquarters
recent work
What's been done in the last three weeks:
  • Replaced ball joints
  • Proportioning valve
  • All new SS brake lines from prop valve back
  • completely rebuilt rear brakes (haven't been touched in probably 20 years)
  • LOUD air truck horn mounted to inner fender
  • New F-series coolant tank and washer reservoir
  • Finally mounted upper seat belt harness
  • pulled the oil pressure switch for the fuel pump (inertia switch instead)
  • bought 2 fire extinguishers (can never have enough)
  • Found an inch of bondo between the "floor pan" where the Pass seat mounts and the actual floor pan
  • Bled entire brake system (ewwww........fluid was gross)
  • Got it out of the garage and under a huge tent behind the garage (Garage is way too small and plus it's my woodworking shop.)
  • removed the "OBSCURE" license plate. :(
Put the Mustang up for sale
Next Post - What's coming up
ObscureMachine
ObscureMachine
World Headquarters
Next few Steps
For the next two weeks:
Moving toward a daily driver and occasional off paved road wanderer:
  • Get it registered here in Oregon (I know, I know)
  • Run All new fuel lines and put in new fuel filters (BETTER SAFE THAN SORRY!)
  • Rebuild the Carb for the 3rd time in 9 years
  • Install new Tom's Battery tray and hold-down
  • New Tires- BFG A/T 33x12.5x15
  • Remove everything possible for sandblasting the interior floors
  • Replace Passenger floor pan
  • Sand blast all the denno Liner in the interior
  • Line-X interior
  • Bronco Bob full cage
  • Remount front seats.
  • BCB Soft Top
  • inertia switch
  • Neutral safety switch
  • Following That (Goals)
  • Centech Wiring
  • Serpentine conversion
  • EFI (Probably Holley Sniper)
  • New Radiator
  • Custom Dash
  • Dakota VHX gauge cluster
  • Pull style hand brake
  • New back seat (roll and tumble? Stop drop and roll?)
  • New springs, shocks and bushings
  • Deal with doors (rust at bottom. New doors?)
  • New Windshield
  • Additional sneaky anti-theft feature
  • A/C
And the list goes on....
ObscureMachine
ObscureMachine
World Headquarters
Level out the body lift
When I put the 2" body lift 4 years ago, I shimmed here and there (a lot in places) to try to make panels fit better. All I did was make the whole body catawampas and give it a lean to the passenger side.
Today I am removing excess shims and doing proper measuring and re-bolting the body down. Then I have to figure out door fitting.
And I removed the rear seat.
BronCowie
Old Timer
Vancouver, WA
Note:
1. I love my hood shocks!
2. I will NEVER, EVER, again own an Edelbrock Carb.
1. Hood shocks are the greatest inexpensive mod ever.
2. My edelbrock has performed excellently since I installed it 10 years ago, but I don't do any aggressive off-road driving.
JGbronc
Bronco Maniac
You should name it Febreeze since you're getting rid of the buttstank issues.
sprdv1
REBEL
You are a busy busy body there, Make it happen brother
ObscureMachine
ObscureMachine
World Headquarters
Tore the carb apart, soaked in in carb cleaner and let it soak overnight. Rebuilt it and slapped it on the bronco. While it was soaking, decided to start doing some engine "detailing."
Not sure why that engine pic keeps uploading sideways. Sorry.
ObscureMachine
ObscureMachine
World Headquarters
First oregon road trip!!!
Well, it was only 3 miles, but.............. IT'S ALIVE!!!!
It starts up immediately, idles great, runs amazingly well!
Needs tires and an alignment b/c it's all over the road, but other than that, it's on the move!
BronCowie
Old Timer
Vancouver, WA
I saw this bronco in person once upon a time... needed mucho attention at that time. Glad to see yer gittin to it!
