A Horse with No Name Build Thread
Episode 4: 4R70W Teardown
My questions to you are in
PURPLE
Updates are in
ORANGE
I never would have attempted this if it weren't for this guy:
I had linked to his Youtube video class in Episode 1. This guy's calm demeanor, detailed steps and speaking voice made the teardown much less intimidating. There are many other great Youtube videos that are also very helpful. A few other ones I liked are
here and
here.
I will be replacing all steels, frictions, seals, bearings, solenoids, accumulators and associated servo pistons. I ordered this
replacement overdrive servo pin because when I placed the original pin in the overdrive bore hole, there is some wiggle which is a common problem from the bore getting wallowed out The new pin has an O-ring to fix this issue.
So here is my 4R70W torn down which was quite simple other than 1 mishap (Concern #3 below). I spilled trans fluid all over the garage floor and now have some nice stains in the concrete which doesn't bother me at all. I cleaned all the trans parts with a 5 gal HF bucket and some odorless mineral spirits:
Upon inspection, the transmission appeared in decent shape. I believe it had been serviced fairly recently as all of the clutch packs were in good shape. I did find some concerns and created one myself (more on that further down
). So as a reminder, my questions to you all will be in
Purple.
Concern #1: Worn sun gear shell
I will be replacing this with a new one because of the wallowed out areas shown with the red arrow. Also the reverse drum it is sitting on seems glazed. It's not gouged
so should I reuse this or replace? The reverse clutch frictions and steels looked brand new so maybe there was an issue previously that was corrected?
See update below
UPDATE: I'm not going to replace the reverse drum. It took all of 5 minutes with scotchbrite to get it looking factory as shown here:
Concern #2: OEM stamped steel forward clutch drum
According to the veterans, this is a common failure part and will get destroyed at the snap ring groove over time due to how thin the metal is. The forward drum looked fine (shown with red arrow) but to prevent this common failure, I ordered this
forged steel forward clutch drum.
Concern #3: My novice mistake
I did not know that a common thing with older engines and trans were broken bolts. Well step 1 or 2 of the teardown involved removing the tail housing. With my brute strength, I managed to break 2 of the tail housing bolts. I tried a penetrating fluid soak for several days - didn't work, I tried the heat with a torch and grab with pliers trick - didn't work. I have never stick welded and I have this cheap welder and I attempted to weld a nut on them -didn't work as the weld failed and I managed to get slag on the housing face which I can probably file off. These bolts seemed bonded to the housing.
So.... I attempted to drill them out with a drill (I have no drill press). I managed to booger up one of them bad by drilling at an angle by accident (too many beers?). The other one is not great either. I had planned to drill them out and re-tap the holes with a slightly larger size. Then I thought maybe I would just use a SS bolt nut and lock washer since the other 4 threaded holes are fine. I have no idea what I'm doing or should do.
Let me know what you would do to fix this. The bolt holes that I messed up are shown with red arrows.
Close up:
