I have read that there is no engine braking when set up in a 2WD car below 28 MpH. I am having trouble getting my head around whether the same would hold true for a Bronco application when there is a D20 between the trans and OD. I just don’t know. And yes, I am worried that it won’t be idiot proof and I will destroy the needle bearings somehow.
Not sure how it knows, or if this is just a generic statement by the manufacturer.
Either way, this relationship should not change just because there is another gearbox (direct drive) in-between.
However, the gear ratios in the differential will definitely have an effect, no matter what vehicle it's in, or whether there is even an overdrive installed or not. As would an automatic transmission vs a manual.
The taller ratios and larger tires naturally reduce the compression braking effectiveness overall. A lower gear ratio and smaller tires would enhance compression braking of the engine.
My '68 with it's barely 30" tall tires and 4.56 gears and an automatic transmission will pull the vehicle down literally to almost an idle speed with engine compression alone. Stock Explorer engine as well, so nothing exotic.
That's all gear ratio there, with maybe some help from a responsive 4R70W trans.
Your 3.50's would naturally have less overall braking effect.
I'm not really sure how a mechanical overdrive knows "miles per hour" anyway. Unless it's programmed to know the gear ratio and tire size, it has no idea what speed the vehicle is going.
So I'm guessing it's more of a generic statement.
