Baja71 said:
Where is a good place to get either the ignition or the two door locks re-keyed to match. Is this something you take to a regular locksmith, or do I need a automotive lock specialist of sorts?
Almost any automotive locksmith can handle. Getting an older Ford sigle sided lock(s) rekeyed by a "regular" locksmith might be hit or miss as the pin kits havent been in as much demand since the last pass vehicle stopped using them in 1977.
I would NEVER file down old used tumblers. And if you see a locksmith doing it, take your parts and run. The upper pins and lower pins are "matched" so the locks work smoothly. Dont mix and match upper and lower pins.
The legs on the pin covers will usually break, the cases are peened over them to hold them in place. This is for the ign and doors alike. It is like painting mice turds getting them out. You need to remove the old pieces in order for the new pin covers to fit properly.
FYI ALL - there are keys designed to "pass" both the ignition, doors and glove box. Properly pinned, one key will fit the entire truck. The only problem is unless you plan it properly when you drop off your truck for service, they can get into your glove box too.
Yes you can make about anything serve as a lock in one BUT if you dont know what youre doing you risk ruining a lock or compromising your truck's security. Not that a Bronco is a highly secure vehicle anyway, but we like to keep the honest - honest.
J. R.
(and registered member of ALOA)
