Cutting a clean hole
birdman
Napa
I need to create a bigger hole in my firewall for my new wiring harness. The hole right now is 1" diameter and needs to be 1 3/8 in. What would be the best method to get a nice clean cut.
I know plasma would be the best but, I don't have access to one.
broncow72
Village Idiot
Spring,TX.
Have any electrician friends? If so ask if they have a hole punch. With he existing hole the holesaw will not work but a hole punch will. This site shows what they are.
B
birdman
Napa
That was my concern with an existing hole the pilot drill would be ineffective. I may be able to come up with something. On second thought I do have an electrition friend. Thanks
1975stroppebaja
I'll second this suggestion. I used an electrician's hole punch to cut the hole in my new qtr panel for my front gas tank. They do a very clean job. Do borrow it though instead of buy because they're quite pricy.
mag409
Central Pennsylvania
Depending on the difference in hole diameter, you can sometimes use a holesaw inside a holesaw. Cut a piece of 1/4 or 5/16 rod, depending on your holesaw pilot size, and put the 1" holesaw onto the rod and tighten. Slide the assembly into the 1.375" holesaw and tighten the setscrew leaving enough to go into your drill. You want to leave the 1" holesaw slightly longer then the bigger diameter. Slip it through the existing 1" hole and fire it up. with this setup you are using the outside diameter of the 1"holesaw as your pilot. Good Luck.
Naildriver111
Rainsville, AL
If you can find a way to align and attach a thin piece of steel over the hole, you could just use a hole saw. I tack welded a plate to the backside of my dash so I could drill a larger hole, but that was before having it painted.
B
birdman
Napa
Good Idea on the double whole saw I may try that I was also thinking of the other suggestion of tacking some sheet metal up and doing that way also.
bax
Old Member
Find the hole saw you are going to use. Drill a hole in a peice of wood, say 3/4'' thick. make sure the peice of wood will fit in the area you want to drill. Line up the wood hole with the hole you want to drill. fasten the wood with screws and washers using some of the other holes close to the hole you want to drill. I am assuming that your truck is apart right now? Room to work I hope. The wood will act as a guide not letting the saw wander and eliminating the need for a center. sounds kind of weird but it works.
bax
bcrump5252
high point
I used a plazma but as u stated you dont have one, I think the only way your going to get a clean hole is with a hole saw. unless u dont care then I would use a sawzaw LOL
B
birdman
Napa
Thanks Bax. I do have plenty of holes to attach the wood and that does sound like it would work. Tonight my mother-in-law is here so I have all night to get this done no rush if you know what I mean. So I will be tinkering until its time for her to go. What a way to spend my day off.
SteveL
Huge chevy guy
Hawthorne ca
uni-dit or step bit are the better drill to use. The best way is a KO set. Electricians and plumbers carry em. I have one on my work truck. They are a hydrolic puller which makes purfect holes.
BigO
If you have to buy a new drill bit, I would buy a UniBit (step bit). I love them! They can easily be used to enlarge an existing hole, make a clean cut, and can be used on other projects for drilling a variety of hole sizes.
deltarat
Drew,Ms
If you have a die grinder and a carbide bit, you can trace the sze hole you need around the existing hole.Then carefully ease up the the line with the carbide bit. The other suggestions are very good,it is just what you have that you can use without buying any new tools. You know how we hate buying new tools...lol
B
birdman
Napa
I went to Harbor Freight today and they did not have a big enough unibit and didn't know when to they would get one. I do have smaller unibits and this would be real easy if I had the right size. I will probably try one of the other methods tomorrow when I have time.
bax
Old Member
a word of caution about using the Knock out tool. the hole you want is not really much bigger than the hole you have. If the fire wall was heavy guage steel then the knock out would work. However with lighter guage steel the tool may just roll the sheet metal back and not cut all of it clean. Good tool but it's not going to work for what you want to do. Only because the hole is close to the same size. If you had a 1/2'' hole it would work great.
Bax
Bax
