It shifts alot better than the way the PO had it set-up................How does it shift? Do you have to wiggle it around to get over to 3 & 4 or back to 1 & 2?
Do you really think most people shift gears holding the stick like a pistol grip?Mad you have to flip that T-handle sideway and make yourself the pistol grip version. ;D ;D
I, myself prefer the ball handle inbetween the thumb, index and middle finger............................... It's that easy...
The springs or detents that you are talking about is in the top cover of the trans which the modified shift linkage doesn't affect it's operation. It will still work the same way.....I have a question about this style shifter and/or the ironbender shifter. How is the 2 to 3 shift? Meaning, a standard shifter in a manual transmission is spring loaded to naturally want to rest in the neutral position, which helps the 2 to 3 transition.
I don't know how the stock NP435 shifter is set up but this heim joint setup seems like there's no preload to neutral, meaning you could easily miss a shift. Not a big deal on the trail, but I'm talking about when driving on the street.
Thanks!
I was looking thru a Mustang mag and found they make the same style shifter for a T-5.
http://www.mustangsplus.com/Merchan...FMP&Product_Code=10450&Category_Code=shifters
That's actually where Jack got his idea from
