gunnibronco
Good points.I’ve always mildly disagreed with the concept of having the front lock up before the rears.
Yes, having the rears lock up could end up with you skating around and “swapping ends“ as people like to say. But I’d rather retain my front steering and braking capacities by having front wheels that are still rolling, and deal with the much easier to deal with rear skid.
I’ve locked up my rears just before the front many times and have never swapped ends. Now I’m sure there are situations where it’s unavoidable, but I’d still rather not lock up the fronts.
With the rears locking up just slightly before the fronts, it also gives you a good indication of where you are in your braking and that you are just about to lock up the fronts.
In some situations it’s good to know that so you can avoid locking up the front and losing some of the control that you still had up to that point.
I'm hoping a proportioning valve will be enough to allow me to dial in a good balance. I'm not even close right now.
I can't even get my fronts to lock up at all (on pavement), but I admit that wasn't the goal. The wheel hop (if caused by the brakes) on the down hill was uncontrollable. It actually turned me sideways across the hill. I was wondering if I was going roll the rig on a "shakedown" run on a simple trail 10 minutes from my house. Derp.
