meanjean73
I have decided to build a Bronco from the ground up with a frame that was given and nothing more. The main purpose will be a trail rig. My plan is to put a 3 link up front and 4 link in the rear, coil-overs, 39-40 ish tall tires. So far I have cleaned the frame of factory brackets. The axles are from a 2003 Superduy. Since I didn't have any axles to start with these were readily available on CL.
When the front axle is centered the differential appears to be further to the driver side than a Dana 44, almost directly under the driver side frame rail.
Anyone have this setup in their Bronco and care to share some pictures. I know this axle has been put in several Broncos. Some visuals may help my vision of this will all come together.
Ill try to upload some picture, I keep forgetting you can't load them directly to your post.
