1966 170 engine fuel pump oil leak
towood
66 with a 170 six. Old fuel pump was leaking motor oil, likely from the top half of the pump (diaphragm that runs the wipers)
Replaced with one from toms broncos and it has oil weeping from the same spot, top diaphragm.
Is this a known problem? Is there a brand out there better than others?
B RON CO
Statesville, NC
Hi, check the dip stick. If fuel and oil were mixing you could have a lot of gas in the crankcase. Good luck
