1969 Bronco Project K.I.S.S build/update thread
frdboy
I acquired this Bronco from a friend a few years ago, he had owned for a quite a while. I don't know the complete history of it but at one point it was on tons and 40's with a 408.
A small engine fire when he was out wheeling caused the removal of the 408 for repair and an explorer 5.0 was installed. He was in the process of downsizing the axles to make it more of a driver and life happened. That is when I bought it, basically sitting on junkyard axles with nothing but mounts tacked in place and axles needing to be rebuilt/geared.
Here are the basics
5.0 Explorer
4R70W/205
3 Link front with a full width D44
8.8 Rear
I finished installing the axles, set them up with a grizzly locker in the rear, zip locker in the front and 5.13 gears. 157846986_10159370102212445_2846810108450660171_n_10159370102207445.jpg 158221916_10159370103062445_3938379352804572107_n_10159370103057445.jpg 157615089_10159370103112445_5491520010688846053_n_10159370103107445.jpg 159169945_10159378258272445_4050655353680577770_n_10159378258267445.jpg 171285485_10159460596157445_4082713217329451748_n_10159460596147445.jpg
172468633_10159463790812445_5340672573880271921_n_10159463790807445.jpg 168540458_10159441634982445_313245506392237971_n_10159441634977445.jpg
frdboy
frdboy
Mounted up some 37 Maxxis RAZR MT's on some Racelines 186513732_10159545349172445_694948260195714051_n_10159545349167445.jpg
frdboy
frdboy
Wheeled this way for the last couple years, added a winch, some explorer cop car take out rear seats. 236823716_10159742606687445_6579116750976601714_n_10159742606677445.jpg 236838616_10159742606612445_5269235059462398523_n_10159742606602445.jpg 369254691_10161279021262445_9135671034106194189_n_10161279020987445.jpg 369260340_10161279021572445_153862528652581831_n_10161279021107445.jpg
frdboy
frdboy
Gonna make some changes to it this year, the wiring mess was killing me so I am in the process of re-wiring it with an American Autowire severe duty kit. I am removing the 5.0 and have started putting a 408W for it. Planning on using a Holley Terminator X Max kit to run it and the trans.
425985142_10161576993492445_5022063105712327024_n_10161576993107445.jpg 425948605_10161576993607445_7065664670341936606_n_10161576993157445.jpg 425957812_10161576993742445_8609565498708194479_n_10161576993237445.jpg 425957036_10161576993962445_7845695319122901889_n_10161576993387445.jpg
frdboy
frdboy
Got a call from the machine shop, engine stuff was ready! Checked bearing clearances tonight, thrust and deck height. everything looks good so I'll get ring gaps set soon and at least get this short block together. PXL_20240222_223841490.jpg
Nice. Any more details on the engine?
How did those explorer seats work out for you?
My cop car takeout (91 mustang) seats have always been my favorites. Even though they are a little tall.
Yours look to be a little lower, and more suitable to a bronco.
frdboy
frdboy
Engine is a 1995 block, Scat 4" stroke cast crank, Scat rods, Mahle pistons/rings. Should end up about 10.5:1 compression.
Have some 225 Highports ordered for it, FTI hyd. roller. Not sure on intake yet, most likely will be ah Holley hi-ram.
I like the seats but I haven't ridden back there. I think they are a good compromise height wise. I love the built in belts. Probably be good for the kids, not so great for a taller adult.
frdboy
frdboy
Spent a good part of the weekend working on installing the American Autowire kit, really a nice kit. Only issue I have had is the connectors that go to the fuse box didn't want to plug in without adjusting the male pins a little to allow the connector to seat.
I am about 90% done, need to order an Ignition switch wiring harness as mine was pretty rough. Need to finish the main power wires, install a couple relays and tidy everything up. Tried to also plan ahead for the Holley Terminator install with some extra leads built in.
My dash was hacked up from years of changes so I fabed up and aluminum dash piece to go over it. Still using the OE ignition switch and heater control.
Got my cooling fan relay, hi amp fuse holders and starter solenoid mounted.
That’s cool for sure. I’ve always wanted to do headers from scratch. Make them the way I want and not the way someone else thinks that they should be.
Not that most of the engineers don’t know their stuff, just that I’m a little odd that way.😁
frdboy
frdboy
Short block going together, custom cam from FTI and a rollmaster timing set. 1000003346.jpg
frdboy
frdboy
Working on building my cam sync, 3.8 mustang shaft will be installed in the explorer 5.0 housing. Waiting on a new gear and it should be good to go. PXL_20240304_122052911.jpg
frdboy
frdboy
Short block is finished up, as soon as heads get here I'll get it back in the bronco so headers can be built. PXL_20240308_124021271.jpg
frdboy
frdboy
One of my cylinder heads showed up so I was able to set up the valve train and measure for PR length. I am going to install the engine so headers can be built while waiting on the other head to show up. I'll pull it back out for final assy.
frdboy
frdboy
Intake manifold came in so I was able to do a test fit with that, looks tall! The hood I have clears it but not by much. Was hoping to use a different hood but I may just have to run this one for this year. Bronco is off to a good friend of mine for header fab.
frdboy
frdboy
Still waiting on other cylinder head. I did get a pic. from my friend that is building my headers. Looks like he is making good progress on those.
frdboy
frdboy
Headers are done, gonna send them out and have them coated as soon as I get O2 bungs welded in. I had him mount some air bumps while he had it, way happy with how everything turned out.
Similar threads
  • Locked
City: San Jose    Price: $20000
Replies
1
Views
653
  • Locked
City: San jose    Price: $20000
Replies
4
Views
656
  • Locked
City: Coeur d'Alene, Idaho    Price: $15000
Replies
4
Views
1K
  • Locked
City: San jose    Price: $25000
Replies
1
Views
830
