1969 Bronco
U-15 - Wagon
6 Cylinder
3 speed - on the tree
The following parts were installed new in late 2018 and early 2019. Approximately 50 miles driven since installation.
New Suspension
Wild Horses Premium 2.5 Inch Suspension System with Bilstein Shocks
Rock Crawler Coil Springs
Progressive Rear Leaf Springs
Extreme Duty U Bolt Kit
Urethane Spring and Shackle Kit
Adjustable Trac Bar 4140 Chromoly with New Bushings
4 Degree C Bushings
Radius Arm Bolt Kit
Steel Braided Brake Hose Set Front & Rear for to accommodate lift
Driver and Passenger E-Brake Cables
Wild Horses Steering Stabilizer
New Front Brakes
Wild Horses MOAB Vacuum Boost Power Brake System
Wilwood Tandem Aluminum Master Cylinder
Front Disc Brake Kit
Full Size Bendix Style Booster
Adjustable Proportioning Valve
Stainless Steel Braided Flex Hoses
New Tires (4)
BF Goodrich All Terrain T/A 30 x 9.5 R15
Front End Alignment – March 2019
Mile Marker Locking Hubs
Fuel Pump (Mechanical)
Line-X XS-100 applied on entire floorboard including the tailgate. Application goes to the top of the bed.
Rear Fuel Tank Strap and J-Bolt
Rear View Mirror
New Toms Bronco Bimini Top and Channel – Black
Existing parts
Engine – 6 cylinder
Engine Block Code – 12 C8DE 60-15B
Holley Model 1940 Carburetor
Needs exhaust manifold gasket (included) replaced.
Dash pad is in good shape with no tears.
Dash appears to be original. There are a few holes on the underside where I believe a stereo was mounted.
Power Steering added from a 1974 Ford V-8.
I believe that both rear quarters, one front fender and the floor plans have been replaced. All replacement panels appear to be of high quality and the installation looks to be of high quality.
There is a small amount of surface rust on each rear quarter panel on the body line just above the gas cap. The rest of the truck does not show any rust areas.
Seats, including the rear bench are in very good shape.
Dana 20 Transfer Case Gasket set included.
Original owner’s manual
Clear Title
Maryland location
See pictures in my garage
Asking $22,500
U-15 - Wagon
6 Cylinder
New Suspension
4 Degree C Bushings
Radius Arm Bolt Kit
New Front Brakes
New Tires (4)
Rear View Mirror
Existing parts
Engine – 6 cylinder
Clear Title
Maryland location
Asking $22,500
