broke_okie
- May 15, 2005
- 264
I have the following for sale:
71' STOCK PANHARD BAR WITH POLYURETHANE BUSHINGS. $50.00. 8#
71' STOCK SPARE TIRE MOUNT $150.00. 20#
71' STOCK RADIUS ARMS MINUS CAPS POLY URETHANE END BUSHINGS $180.00 . 35#
71' STOCK RADIUS ARM FRAME BRACKETS WELDED ON 4" BLOCKS $20.00 15#
71' STOCK EB CHARCOAL CANNISTER W/ BRACKET $10.00. 3#
71' STOCK EB BRAKE CABLES FRONT/REAR/ CENTER $30.00 FOR ALL 3 IN SET. 2#
71' STOCK EB FUEL PUMP $10.OO . 2#
71' EB 2.5" RANCHO FRONT COIL SPRINGS $20.00 35#
CHEVY DISC BRAKE CALIPER MOUNTING BRACKETS ONE WITH SPINDLE $100.00 . 25#
NP205 T CASE TO NP345 MANUAL TRANSMISSION ADAPTER TRAPEZOIDAL $300.00 30#
STOCK 71' CLUTCH ROD $10.00 1#
71' STOCK FRONT 18# AND REAR 22#DRIVELINES $200.00 BOTH OR $100.00 EACH 40#
FORD 302 ALUMINUM BELLHOUSING $185.00 10#
71' STOCK CLUTCH FORK CLIP STYLE $10.00 3#
302 SINGLE GROOVE WATER PUMP PULLEY $10.00 2#
302 DOUBLE GROOVE CRANK PULLEY $10.00 2#
71' STOCK TCASE X-MEMBER $50.00 12#
71' STOCK TRANSMISSION RUBBER MOUNT $10.00 2#
71'STOCK 2 BBL CARB SPACER $10.00 1#
(2)71' STOCK DRUM/DRUM PROP VALVES $10.00 EACH 2#.
STOCK 71' COIL SPRING CUPS BOTH INNERS/OUTERS 4 pieces $50.00 3#
If you need pics just text me it would be faster than PM 's. PICK UP ONLY WILL NOT SHIP ANY PARTS CTC TONY AT (559) 994-9681
