BroncoClubofAm
- Feb 18, 2020
- 3
I have a bone stock 72' with a 302 manual trans. After sitting for two weeks it would not crank, nothing. No click, no noise. Headlights and heater fan work. So far I've done the following to no avail:
- tested battery 12.4V
- replaced solenoid twice (thought I got a bad one, upgraded to higher grade)
- R&R starter and had it bench tested, it passed. Eventually tried a new starter as parts employee inspired little confidence. Both starters passed my test on garage floor connecting jumper cables.
- replaced cable from solenoid to starter
- Inspected and cleaned negative cable on battery side and at the block
- Removed starter side wire at solenoid, tested by cycling ignition. When moving key to starting position it reads 12.4V then goes back to 0 when key is off. Tested numerous times and it reads 12V or better each cycle.
- If you bypass the solenoid it will crank and turn over. Maybe I wasn't using a high enough gauge wire but it got hot and started fusing to the solenoid.
- If you put a wire to the positive cable and then touch the "S" side of the solenoid, it will NOT crank.
I'm stumped. Any help would be appreciated.
