    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
MT 1974 Bronco Built
GloNDark
City: Helena
Price: $ 60000
Posting this for a friend who does not do social media or the forums. Feel free to PM me with questions or call: Wade (406) 461-1617
Price is $60,000 OBO
Specs
West Coast Broncos Fiberglass Front Fenders
Dennis Carpenter Windshield Frame
Dennis Carpenter Grille
Dennis Carpenter Tailgate
Original Ford Dash,Doors and Hardtop
Frame
Frame Stripped down to bare metal and painted with KBS Frame Coater
James Duff Full Width Front Coil Spring Bucket
Toms Broncos Fuel Tank
Frame mounted fuel pump and filters for EFI
Suspension/Axles
Front axle Ford High Pinion Full Width Dana 44 w/ Spartan Locker
Rear axle Ford Full Width wi/ Curry Third member and Tru Trac. Full width axle truss and Ruff Stuff Disc Brake Conversion
Wild Horses Anti Wrap Bar
Wild Horses Inboard Rear Shock Mount
All new brake part calipers/rotors
Yukon 4.56 ring and pinion gears
Ruff Stuff One Ton Steering
Ruff Stuff Differential Cover on front axle
James Duff Extended Long Travel Radius Arms and brackets
Wild Horses 3.5 Front Coil Springs
James Duff Heavy Duty Coil Spring Cups
Toms Bronco Parts 3.5 Rear Leaf Springs
1977 Ford Bronco Power Steering Box (Built and Ported for Hydro Assist by West Texas Offroad
Wheels and Tires
Nitto Trail Grappler 37x12R17 tires
Raceline Monster Simulated Beadlocks
Spare tire BFG All Terrain on Method Wheel
Motor/ Transmission/ Transfer Case
Ford 351W Hydraulic Roller Cam Motor (Built by SNJ Engines in Spokane WA.)
Holley Sniper Fuel Injection
Edelbrock Performer Intake
RV Type Cam (sorry I can’t find grind sheet)
Summit Racing Ready to Run Distributor
MSD Coil
MSD Ignition Box
MSD Spark plug wires
FlowKooler water pump
WH Saginaw dual return power steering pump and pulley
Toms Off-road Stainless Shorty headers (2 into 1 exhaust)
James Duff 2 into 1 exhaust system
Headers and exhaust system have been
coated outside and inside by Jet Hot Coatings
Transmission
Ford Bronco C-4 Transmission
Hughes Performance Heavy Duty RV torque converter
Deep Aluminum Trans Oil Pan
Hayden External Transmission Cooler
New hardware ( mounting bolts etc)
Transfer Case
Dana 20 Rebuilt by Jeff’s Bronco Graveyard
New gaskets,seals and bearIng
New hardware (mounting bolts etc)
WH/ Advance Adapters Extreme Duty Output Assembly
JB Fabrication Twin Stick Shifters
Brakes
WiH/ Wilwood Hydroboost Brake System
Front brakes are factory disc
Rear Brakes Ruff Stuff Ford 9” Disc Brake Conversion
Electrical
American Autowire Bronco Specific Harness
Autometer Comp Z Series gauges for Fuel,Electric,Oil Pressure,Water Temperature and Transmission temperature
Toms Bronco Parts LED Headlights, Turn Signals and Brake Lights
Interior
Toms Off-road Six point family roll cage tied into frame
Factory dash and gauge cluster along with Autometer Gauges for accurate readings
Bailie Bilt tool trays
Best Top Front and rear seats attached to roll cage
Miscellaneous
All weatherstrip and seals for body and top are new
Baile Bilt Bilt Cool Stainless Vents installed in engine bay
Toms Bronco Parts Three Row Aluminum Radiator
WH Stainless Radiator Core Support Tool Tray ( great for focusing air flow on radiator)
WH Polyurethane Body Bushings w/ new hardware
Wild Horses Aluminum Transfer Case Cover
thumbnail_image8-jpg.920985
thumbnail_image7-jpg.920984
thumbnail_image6-jpg.920983
thumbnail_image5-jpg.920982
thumbnail_image3-jpg.920980
thumbnail_image2-jpg.920979
thumbnail_image1-jpg.920978
thumbnail_image9-jpg.920986
