roughhog
Newbie here and looking for help. Any help will be greatly appreciated.
I talked to the guy earlier and he said he was unsure about the motor but he thinks it has something wrong with a fuel line. But let me know what you guys think. I could use all the info you guys have to throw at me. This will be my first Bronco project and I'm wanting to make this as good as a experience as possible.
He is asking 2200. The info below is all the info he has gave me so far. Check out the picture and tell me what you think. He did tell me that the pics of the whole rig make it look better than what it is.
The worst stuff: (see Pictures)
* Right side ; Rust bad at rear jam of passenger side door, where a galvanized patch was screw/d in place to hold door jam…also on inside rear fender hump –shown after I pulled up the carpet is rusted thru…..This area between the door / and ahead of the wheel is the worst rust area in the vehicle – strange?
* Left side: Needs front door post (typical Bronco drivers door sag at the hinges- thing).
Rust along seam below mid side trim.
Rusted out around the Aux. Gas cap filler cover- another strange rust area.
* Rear: Bumper bent & Licence holder bent from impact. Rust along tailgate seams
Rear lift gate latch does not work (just spins?)
* Interior: Front floors have some typical rust thru
Front seat upholstery’s are shot.
Rear seat is stored in garage –good?
Pass side interior door panel is missing?
* Bottom of Bronco/Frame: Looks pretty good !?
except floors/ which are rusted as typical …
wheel well openings are uncut and in good condition.
* Doors: Good -except
a lower scuff(dent) in Pass door
Drivers door a rust hole in middle where a later model Mirror was attached
* Engine: Covered with dirt and nuts (Squirrels) Non Original air Cleaner .
Engine turns freely – should be no reason that it would not run –
Engine did not use oil and transmission was good.
Mileage: Vehicle shows 4,304 miles….. (104,304) and has not moved for at least 15 years.
