1990 Bronco brake light problem
pcon
Newbie
i have a 1990full size bronco. the turn signals are working but i only have the right hand brake light. any help would be wonderful. pcon.
P
pcon
Newbie
i have a 1990 full size bronco ,the turn signals are working, the emergency flashers are working the right hand brake light is working but i cannot get the left brake light to work.bulbs are all new .help please pcon
jerry
Bakersfield, CA
Hey Pcon,
Like Jon said, one of the other sites may be of more help.
Having said that... I'd check two things:
Sometimes it's possible to install a bulb backwards, so maybe try rotating it around? (Especially true with some LED bulbs.)
Did you check for power with your voltmeter at the socket? Also make sure socket and its terminals are clean - for example, dielectric grease on contacts will cause problems.
HTH,
Jerry
