Tonka7777
1994 Ford 351W out of a Bronco. No longer have a need for it. It had 60K miles on it before the rebuild. It was built by Scott Noe of Noe's Performance in Morristown, TN about 5 years ago. Totally stock rebuild (stock bore & stroke), Bores were honed & crank polished, new cam bearings & freeze plugs, new valve job was performed and new valve seals on the heads. We used Sealed Power main/rod bearings,stock rods/pistons, Sealed power piston rings, Edelbrock Performer timing gears/chain, Melling oil pump, Gates water pump. Stock '94 truck camshaft was reused. It has a brand new NOS Ford Oil Pan that has been KBS coated silver, new timing cover, Chrome valve covers, new Motorcraft plugs. The original distributor and oil dipstick. Painted Old Ford Blue with Eastwood Ceramic engine paint. The original intake is still on it. Been sitting on a stand, wrapped up, crank turned every 3 months. Comes with the upper intake, original Ford valve covers, wiring harness, and air intake parts. Stand is included.
