harleyabarton
so i have a brand new 302 from blue print ran it natually asperated and it made 330 horsepower to the crank! pretty good for a old bronco but i wanted to supercharge it (vortech). so i did and while installing it i installed a msd dizzy and ignition box and coil. i installed a fitech 30004 (the supercharger version)
after getting everything to finally work (kinda it still randomly dies) it now runs and idles great and will rev at WOT great! i have a locked out distributor set to 34 degrees at 3500 rpm. the thing eats gas like crazy and smells like unburned gas... i mean like i had a half a tank of gas yesterday and all i did was idle it and set the timing for about 10 minutes and it used the whole half tank!!! but it sounds great and runs like a normal engine!
only problem is it has NO power. if i had to guess its hitting like 100hp at maybe 1600 rpm then just diving... i can get it to get into all gears but if you try to start it in first and you dont jam the gas pedal itll bog down as if it has NO gas. im so confused! is this a timing problem? are spark plugs bad? or is it just the ignition box? or the fuel injection? i dont understand why it's great and revs perfect without it in gear and then as soon as it has load it just doesnt wanna move out of its own way!
