BruiserOutdoors
- Aug 22, 2013
- 741
Running a 306 sbf with about 10-12k miles since it was built. It has a moderate cam in it. Bought the motor from a local bronco brother. I heard it run and got to ride along prior to buying the motor. It seemed to check out for the most part.
When I installed it, I installed an msd billet distributor and edelbrock avs2 carb. I did not install the vacuum advance mechanism due to being in a rush for an event. Now under moderate to heavy throttle, the motor will ping. It has always seemed to run rich and smelly, and now seems to smoke white smoke out of both tailpipes when warm. It has true dual exhaust, no crossover H pipe.
Are these issues related? Did I cause damage by not having the timing setup correctly?
How can I tell if its bad rings or valve guides?
Cause of the pinging?
