Last week I put in the 4r70w transmission. For those who are not familiar, it is an 4 speed (including overdrive) transmission that is electronically controlled.
I wanted to put together a list of the things that I did so that others have something to reference. I'll try to get afew images posted. Let me know if you have any specific images you want to see.
engine: 1992 5.0 block with explorer EFI
cam: crane cams 444211
torque converter: Pro-King FM69L from advance auto parts; it was the lowest stall I could find (k = 110; 1700 rpm actual stall on my setup), I wish I went with the medium stall FM69 (k=140; ~2100 rpm); explorer stock come with a high stall (k=168; ~2550 rpm)
transmission source: 2000 4x4 Mercury Mountaineer with 5.0 engine
controller: Baumann Engineering ; the new USB controlled one (Opti-Shift) - it is really nice I can check things like tranny temp and road speed from its onboard screen
adapter: advance adapters 50-2704 (from Toms Bronco Parts)
sleeve and pin set: advance adapters 716057
front driveshaft: front driveshaft from a 1992ish explorer (2 inch diameter), cut down to length (25.75 inches)
Rear Driveshaft: BC Broncos rear, cut down to length (31.25 inches, i think)
transfer case: Dana 20 J shifter with twin stick (needed to modify twin stick slightly since AA setup does not exactly match stock adapter)
shifter: B&M sport shifter - needed to make custom lever and attachment (selector arm was 2.10 iches center to center)
crossmember: modified per AA instructions
Crossmember suports on frame: modified existing mounts by cutting off back and welding on an extension bracket
headers: Doug Thorley long tubes will fit, but are very tight; I went with HED-88400; I wish I went with HED-88408 since they have thicker flanges and tubes and are also coated
Fittings at tranny: brass 1/4npt male to 3/8 inverted flare male, 90 degree bend; from Napa (2)
Fittings at other end of hard line (2): brass 3/8 female invertered flare to hose barb for clampless connection (no hose clamp require = awesome)
Hard Lines: 4 feet of 3/8 inverted flare from Napa (2)
Soft line: 10 - 12 feet of 3/8 transmission line from hydraulic parts store
O2 sensor bungs (2): put into each of the reducers right after the ball/socket joint
Tranny fluid (14 quarts): Castrol Mercon V
