edinning
I'm not sure how to add photos sorry. Please e-mail me.
THIS IS A CUSTOM BUILT FRAME OFF RESTORATION. ONE OF A KIND 67 BRONCO BUILT FOR EVERY USE. CURRENTLY TAGGED & STREET LEGAL!!!
There was a complete frame off restoration completed about 8 years ago. The Bronco was used in car shows for the first 4 years and never off road until 3 years ago. The restoration was designed for show but with the intention to use for trail & Street .
New ,rebuilt or upgraded since 2005 are = Trans complete rebuild w/new clutch,T-case re-seal,Pwr brakes added,Yukon Frt axles inner and outer,Warn hubs, Pwr steering pump,Alternator,Halley T/A 470 Carb, Crank and piston bearings,oil pump and pick up, 5 Wheels and tires, Frt and rear springs and hardware,rear spring rockers, new plugs and wires,CB added, rear drive shaft and yoke,Frt locker switch, Stone Crusher Steering,and completely rebuilt Frt suspension and steering.
37" Procomp X-Terrain less than 3k miles of use
16" Procomp wheels
4whl disc Pwr brakes-BC Bronco
Flaming river steering column and EZ fit shaft
5.5" lift-BC Bronco springs and rockers
Rock Crusher steering links
Custom long spline drive shafts -Driveshaft super store
23gal EFI fuel tank
6pt role cage
Strong 302 new lower bearings
Holley Truck Avenger 470 Carb
Np 435 complete rebuilt
Center force clutch
Dana 20 T-Case.
Warn HS 9500i Winch
D44 Frt w/Yukon axles 4.56 gears,ARB locker,Warn hubs
9" rear by Currie, 4.56 Detroit locker
Custom dash & interior
Custom rock slides
Custom cowl hood
Interior and underside Line X
Originally from Arizona and is free of major rust. There are some small spots of surface rust only. I have doors but no full top. There are full soft top kits sold that would work well if needed.
I can take and e-mail any photo requested to help with Bronco details. Also Please feel free to call me 410-913-3696.
I will know think about the offers I recieved over 12K.
16" Procomp wheels
23gal EFI fuel tank
6pt role cage
Center force clutch
Dana 20 T-Case.
Warn HS 9500i Winch
Custom rock slides
Custom cowl hood
