tlyoung003
I purchased a 75 Bronco that the PO installed an NV4500 transmission with an adapter for the Dana 20 transfer case. For my use, I will be converting to a 4R70W transmission. The Bronco is non running today but has a rebuilt 89 5.0 HO engine running about 400HP. Is has a new painless wiring harness. It also has the RJM EFI engine harness for classic fords.
1. What make, model and year 4x4 4R70W should I be looking for a rebuildable tranny from?
2. The PO had routed but not terminated the wiring. He seperated body fuse box in the glove box and engine fuse box on the passenger fender. The CPU I have for the motor is EEC-IV SFI-MA12A01B14 A3M1. What do I need to do to have them communicate with each other?
3. Also, if I want to cruise on the highway at about 70-75 MPH at low RPM's, what gearing should I have in the front and rear differentials?
Thank you
Thank you
