mofoco1
I am converting the 74's drums to disc using a donor 79 caliper brackets and gut. I already bought some 79 drilled and slotted rotors, new Stainless Steel extended brake lines, new disc/drum proportioning valve, big Bird calipers and banjo bolts and correct pads. So here's the ? have to use the spindles off the 79 right to match the bolt pattern on the caliper brackets? I assume the same for the hub not the locking hubs, but the the actual hub? Or are the hubs interchangeable cause the drum hubs are in better shape? Can and has anyone ever chrome or Nickle plated a set of again Hubs, or is the tolerances on the splines and and bearings surfaces too close to risk it. Even with prep and clear coating on new hubs they always discolor and turn brownish. Trying to get them to stay new looking if not actually shiny. Do we have in the archives the old 78-79 Bronco to early 44 conversion instructions, if so a link would be helpful. same for anyone has installed the J-shift twin stick conversion, can it be do with out a huge tunnel cutout ? I have a 3" b-lift that I want to remove but I want the twin stick done prior...thanks......Mo in Clovis, CA
