- Jul 31, 2001
- 8,858
Hence the title- The numbers blew me away. I couldnt image that a round driving light would have 10 times the drag that an aerodynamic shaped strut or wing would have.
Check this out.
Multiple times on mpg threads I have shown what lifting a Bronco does to mileage. I used to keep logs on mileage, lube, maintenance stuff and installing a lsuspension or body lift, larger OD tires on my Bronco affected my mileage significantly.
Just thought this youtube video backed that up. Course all you "airplane guys" knew these drastic numbers already!
Here is a great video that all airplane builders have seen or should have seen. Same on cars or anything going through air. Round objects have almost 10 times the drag of a streamlined object with the same thickness.
This video is worth the 5 minute watch.
https://www.youtube.com/watch?v=ftq8jTQ8ANE
Check this out.
