Don't want to sound like a know it all but, it's "first in last out". A dent is a stretch in the metal. If you pull the center out till it is flush, by the time you have the outside pulled, the center will then be pulled out further. The PPG DP products are good, and less expensive than what we use in the body shop today, but I would'nt put anything more than metal glaze over it. If you only have spots of bare metal use a self etching primer like Standox 1-K it is available in a rattle can. New paint sticks better to clean, etched, old paint better than anything. I'd still use a sealer primer to pervent lifting of the old paint. These can be any color even transparent. 2bad is correct in what is under the paint is far more important to the appearence of the paint job than the paint itself. Not only to the smoothness of the job, but color as well. ei painting white over black will make the white appear brighter. Lighter colors are more forgiveing. Darker colors don't cover very well. So a uniform color underneath will help the color look the same all over. Talk with a local paint jobber, he'll help with what products to use. Hope this helps. ;D
