Any tricks to installing carpeting over wheel tubs?
bgaller
I'm finishing up a 74 Ranger and need to install carpet over the wheel tubs, but having a really hard time getting it to lay flat without wrinkling. I ordered a carpet kit from ACC, and while the wheel tub carpet was molded in a half moon shape, I just can't seem to get it to lay right. Any tips?
BGBronco
N A S H V I L L E
Tennessee
Mine seemed to lay pretty flat . Top was held down with trim panel l bracket and bottom stayed in place tucked under the floor carpet. However, when I rhino lined the floor a few months ago, I decided not to reinstall the wheel hub carpet.
billh1289
Jackson, NJ
I let mine warm up in the sun then used 3m spray adhesive and worked out the wrinkles as I went.
Slowleak
Georgia
If stretching will get it flat then try a heat gun on the backside. You may also be able to use padding under it in spots to even it out.
cdj7k
Newbie
I just did mine a couple weeks back and I found that if I cut as much of the excess off I could they laid better.
